Wiring Aftermarket Lights To Factory Switch?
Old Dec 29, 2012 | 01:56 PM
wheelgarage's Avatar
Originally Posted by Discolife
Im following this, As we are getting ready to get front bumper lights and rear LED work lights.
I am wondering if there are any good LED front fog lights worth a look?
There are many out there, the good ones cost $$$.
Originally Posted by s10lowrider1994
Fiddled around with things to right and got it all figured out. I wanted to be able to control the lights by themselves without linking to the high or low beam. What I did was ran a 12v switched source that comes on with the ignition to pin 1 of the factory switch. Left pins 2 and 5 alone as they simply illuminate the switch itself. I connected pin 4 to # 86 on the relay included with the kit. Ran the other wires from the relay as directed and now I've got working lights.
Ground? If it works...it works!
Old Dec 29, 2012 | 07:50 PM
s10lowrider1994's Avatar
Grounded the relay to the firewall, grounded each light individually to the frame and retained the factory ground for the switch. They outshine the high beams by a ton which surprised me.
Old Dec 29, 2012 | 07:53 PM
Discolife's Avatar
I think you will find that if our lights were directly connected to the battery they would much brighter also.
Common upgrade in some 4x4 circles to do just that. My bronco would only get 10-11.5 volts at best. Just imagine our headlights with full voltage.....
I could be wrong but im pretty sure we dont get12-14 volts to thelightbulbs.
Frank4
Nov 21, 2015 05:47 PM
HeliRy
Headers, Intake, & Exhaust
Jun 28, 2013 10:38 AM
tjhappel
Feb 20, 2011 07:54 PM
cnterline
Feb 15, 2009 05:11 PM
ajh
May 13, 2007 01:12 PM
