Won't shift out of park
Old Jun 24, 2016 | 11:58 AM
KB11707's Avatar
Default Won't shift out of park
My brake lights do not come on, my turn signals do not work, and it will not shift out of park. I have replaced the stop lamp switch already so that is not the problem. If I jump the green/orange to the green/purple wires in the connector it doesn't do anything. And my rear defroster doesn't work so jumping that to the 3rd brake light won't work either. The only way I can get my lights to come on and shift out of park is if I run a wire from my battery straight to my 3rd brake light.
Old Jun 24, 2016 | 10:07 PM
XCELLER8's Avatar
sounds like no power going to the brake light switch.....download the RAVE manual for the electrical circuit diagrams, but you can check the simple stuff first >>>check the fuses under the steering column, there are several relays behind the drivers and passenger's side kick panels.....the RAVE diagrams will help a lot
also....what year is your truck ?
Old Jun 25, 2016 | 10:14 AM
KB11707's Avatar
It is a 96
riggskwong41
Dec 4, 2014 10:59 PM
PiperC
Jan 13, 2012 02:17 PM
Joentuff
Mar 14, 2011 10:02 PM
charliesdiscovery
Jun 6, 2008 02:39 PM
Cirrus
Jul 27, 2005 10:51 PM
