Wooden center console
Old Nov 25, 2013 | 07:15 PM
Britchick1980's Avatar
Default Wooden center console
HAs anyone ever tried replacing the wooden center console on a 98 Disco? Mines in a terrible state and I've found a replacement on eBay. I don't, however, want to fork out $100 on a replacement part only to find out the other is nigh on impossible to get out :-/
Old Nov 25, 2013 | 09:26 PM
abran's Avatar
I'm not sure if the wooden one installs differently, but I'm guessing yours is just plastic with wood veneer, if so:
1) pop off bezel around automatic shifter base.
2) pop off bezel at base of diff lock shifter, then unscrew **** and remove(lefty loosy).
3) open console storage, remove 2 screws at base/bottom of storage.
4) lift up boot on e brake to expose the brake cable connector. There is a clip that slides onto the post, take off/pull up clip, push post out. Then pull e brake up vertically till its almost standing straight up.
5) lift out center console carefully.
If you need photos of a certain part of the process, let me know. Step 4 is key to not break the console during removal.
Good luck
Old Nov 26, 2013 | 06:15 AM
Ah, I was actually talking about the wooden bit that goes from the window switches to the diff lock gear ****. But thanks for that lol!
Old Nov 26, 2013 | 06:23 AM
CUpgt's Avatar
Pop off the bezel around the shifter and pull up the cdl boot. Unscrew the two screws and lift the front to unhook the two hooks on the window switch side
Old Nov 26, 2013 | 07:26 AM
Thank you.
Old Nov 26, 2013 | 10:18 AM
abran's Avatar
Forgot to mention the window switch plate! Also dis connect the wires at the back of the cig lighter while the console is pulled up slightly.
Old Nov 26, 2013 | 07:00 PM
CUpgt's Avatar
The wooden piece has the switches built in
Old Nov 27, 2013 | 09:24 AM
wrongway1's Avatar
Good luck
I'll take those photos!! have a replacement console, and it will save the trial & error phase
Old Nov 27, 2013 | 11:07 AM
abran's Avatar
Default Photos needed...
I need to take them, is there a specific photo that you need? Its pretty straightforward except for maybe the e brake cable.
Let me know what you need most.
Old Nov 27, 2013 | 01:57 PM
wrongway1's Avatar
If that's the hard part of the exchange, then the brake cable piece will help. Thanks!
Paul Flude
Mar 20, 2013 04:31 AM
sna77
Jul 10, 2007 06:02 PM
ramwheel
Apr 23, 2007 10:59 PM
BuckMontecristo
Jul 21, 2006 09:27 PM
LordOphidian
Jul 20, 2006 06:29 PM
