Work has started, Om617 into 95 Rover.
#21
#24
#25
I have access to someone that can make it for me. The raw Aluminum plate is 200 bucks by itself. With the knowhow and work involved that price is not actually that bad...
Course, there is a LOT more to the build than just the adapter plate.
Short list would be
Flywheel adapted, (In my case we are going to use the stick rover flywheel and insert part of the mercedes flywheel in it to correct the bolt pattern, or something like that)
Engine mounts, A/C mounts, Oil pan alteration, 2" body lift + a 3" regular lift and Possibly a 1 inch spacer on that... Just to deal with the clearance issues of that pan (Jerak has a total of a 6 in lift running 37" tires and says the clearance of the pan is fine) Of course that would = better axles etc...
I don't see this being something that is going to be a cheap swap, even done half ***, which who would want it half *** anyway?
#26
Dropped off the Clutch, pressure plate and flywheel yesterday to get redone. The place is going to beef up the clutch all they can in prep for using it with the om617. (Still it's only a 10 inch clutch, so it will be interesting to see how it holds up) Total price for the this step, 140 bucks. When I get the items back the flywheel will head over to the machine shop and get modified to the om617's bolt pattern.
#30
