Wtf!!!!!
Old Aug 17, 2012 | 04:06 PM
Jmcavscout's Avatar
Default Wtf!!!!!
Ok so I changed out my wires with 8mm and my spark plugs with autolite plantinum plugs. My truck drives fine for a while but if I leave it running it idles for a little bit and dies. If I shut it off then start it again it starts but sputters barely to 5 mph and then dies. After that it does not start up again until it cools down and then drives just fine again, but the process starts over. So I have no clue what the issue is. No fault codes no check engine light nothing at all. Fuel pump is a yr old fuel filter is brand new to. Please help before I take it to the range and blow it up.
Old Aug 17, 2012 | 06:11 PM
Danny Lee 97 Disco's Avatar
You did the spark plugs and wires, what about the points and dist cap?
Did you reset the timing?
The 95 has a distibutor, 96 and up have coil packs. Yours has a amplifier that does tend to go bad. They sell an amplifier relocation kit, do a search on that as I am not well versed on the95, mine is a 97, big difference between the two.
Old Aug 17, 2012 | 06:39 PM
Jmcavscout's Avatar
I did not change the distributor cap or rotor. They both look to be in good shape but I'm not certain. Did not mess with the timing cause I thought it was unnecessary. And where can I find this amplifier so I can look at it? Thanks for the reply. I have been working on this truck forever and cannot figure it out.
Old Aug 17, 2012 | 07:47 PM
Get different spark plugs, Autolites are the ones you use when you have a problem and you are selling it and you need it to run just long enough to get it sold.
Seriously, I used Autolite Iridium plugs once, they lasted about a month.
You cannot go wrong with NGK, Denso or Champion.
Old Aug 17, 2012 | 07:48 PM
Either at the distibutor or relocated with a kit from AB.
See Amplifier Module Relocation Kit (Part # STC1856) - Land Rover ignition from Atlantic British
and Land Rover Ingnition Amplifier Module (Same Fit As Genuine Part # STC1184) | Land Rover Engine Parts
Old Aug 17, 2012 | 08:44 PM
I just saw your signature, did you do all of that stuff before or after this started happening?
Old Aug 18, 2012 | 06:51 AM
antichrist's Avatar
On both my 95's the amp module is on the side of the distributor.
I've been using Autolite copper plugs for years without any issues. I usually buy them because when I need them they tend to be the cheapest at the time.
Anything fancier than copper are a waste on D1's IMO.
Old Aug 18, 2012 | 04:04 PM
I agree with Tom, use the cheap Coppers, I usually get the Champion Coppers for aout 2 bucks each. They work fine in mine.
I also see in your signature "Cold Air Intake" if that is one of the oiled ones, you should get that off of there before you do in your MAF.
With a distributor, you can have issues with the cap that may not be obvious to thye naked eye. Carbon paths that cause misfires.
I would put new rotor cap and rotor button in, new points (if it has them) I guess it does, and set the timing. You only did half a tuneup! And get one of those amplifier relocation kits.
Tom knows a lot mor about the 95 than I do.
Old Aug 18, 2012 | 08:16 PM
I agree with the cheap cooper plugs, I'm just saying to use a better brand is all, Autolites are made by the same people who make Fram filters.
Old Aug 18, 2012 | 08:27 PM
Default Tuning a 95
I recall our young Marine caleb Bo had a 95 and did not have a timing light or know anything about setting trhe timing. I had a timing light in my tool box left over from my 73 Mustang, so I sent it to him.
I would think that since the 95 has a dizzy, you should also have points to replace? and the need to at least check the timing and adjust for optimum tune, unless they are a lot different than what I am thinking, but since it was an early 60's buick V8 I would expect it to be that configuration.
I guess that's a generation gap thing as well since all of the "modern" cars do not have any adjustment of that nature. Maybe reflash or upgrade a chip or put on a "tuner" like the Bullydog for the diesels.
