WTH....Drive Side Panhard Bar Bolt
Old Mar 30, 2016 | 04:37 PM
Nitrojunkie383's Avatar
Default WTH....Drive Side Panhard Bar Bolt
Ok, So i thought i would swap out my panhard bar bushings today, but i ran into a little setback. I know how to work around it, but maybe someone can enlighten me as to why this was done like this. I cannot remove the drive side bolt for the panhard bar because it will hit the radius arm.
I know i can jack up the frame enough to get the bolt to clear the arm, but I thought might throw off my "alignment" with the panhard bar when I go back to install it....creating more work. Am I missing something here?
Can I install the bolt back the other way....cant see any reason why not.
Old Mar 31, 2016 | 10:25 AM
Island_Dave's Avatar
I generally find older Land Rovers (D1 and older) quite easy to work on with very few "WTF?" moments but that is a little strange.
If it were me, I'd cut off the bolt and put a new one in the other way round.
Old Mar 31, 2016 | 11:47 AM
fishEH's Avatar
"Hey Nigel, boy will this guy be confused when he tries to change his panhard bushings!!".
Pretty sure that's how it went at the factory.
As mentioned, cut it. Push it out as far as you can and Sawzall it. Drive the rest out with a punch. Reinstall new bolt the proper way.
Old Mar 31, 2016 | 11:57 AM
Thanks guys. Looks like i will be making a trip to the hardware store.
And I agree, this disco has been pretty straight forward to work on. This was just one of those moments when it just seemed to be completely backwards for the British to do that. What I thought would be a 20min job has now turned into a 3hr deal by the time i run around and find that bolt.
Old Mar 31, 2016 | 12:12 PM
Buddy Lee's Avatar
I've never had that issue, I guess because all my trucks have been lifted. I would have just jacked the frame up a little to get it out. You will need to use a ratchet strap to align it again anyway.
Old Apr 1, 2016 | 10:18 AM
landy_ala's Avatar
The only WTF moments I have on the D1 usually come from the electrical.
Old Apr 2, 2016 | 05:37 PM
Detoured Discovey's Avatar
I've 'owned' this moment, with 'that' bolt myself......documented the moment in my build thread. It's 'utterly' ridicules as well as the bracketry 'created' in that area...........some one was trying to justify their job.....total BS, the engineering is simply.....over the top deluxe!!
Found my bolt to even be worn thin.......I've worked on much older vehicles, and never witnessed that....So many 'amazing' moments working on these things....
chicane
Sep 21, 2014 10:53 AM
vette427sbc
Sep 11, 2014 11:37 PM
honda50r
Feb 15, 2013 10:47 AM
collector87
May 16, 2012 05:11 PM
wheelgarage
Jul 6, 2011 02:09 PM
