yet another issue
Old 10-19-2010, 07:08 PM
pwr198's Avatar
Default yet another issue
fix one find one. Now when I make a tight turn I hear a clicking sound?
Old 10-19-2010, 07:28 PM
NiteTrain's Avatar
probably CV joint going out
Old 10-19-2010, 07:49 PM
geek_IM's Avatar
Or a rock stuck in his tire.
Dude, seriously, wtf
more info = better help. Nobody can give you any kind of help off a one sentence post like that.
Old 10-20-2010, 08:49 AM
okdiscoguy's Avatar
I am leaning towards CV as well. Have someone make tight turns in a parking lot while you listen from the outside.
Old 10-20-2010, 09:09 PM
XCELLER8's Avatar
3x on the cv............mine did that when I first got it.....supposedly thats why the po got rid of it. When I went to replace it I found that it was bone dry...no gear lube , no grease. Let us know what you find
Old 10-20-2010, 09:44 PM
My Bridgestone Duelers are terrible about picking up gravel from my driveway. You'll be driving along with ticking noises driving you crazy and it turns out to be a few little pieces of gravel in the tread grooves.
Old 10-20-2010, 11:29 PM
bmxermike's Avatar
I have those tires too, looked around under the truck after every drive because of it for awhile.
Old 10-21-2010, 09:34 AM
So, lets get away from the rocks and back to what is most likely starting to fail. When was the last time you did a complete front diff. service, bearings Swivel fluid, seal and a setting of the preload? You may be out of swivel oil, causing the cv joint to talk to you. There is a slight chance, depending on it mileage and how low the fluid is, that you may prolong it's death by filling both swivels.
Old 10-21-2010, 09:43 AM
jbriggs's Avatar
Ditto what Mike said. I filled both my swivels while I'm waiting on the CV joints to arrive. Lock it in 4 wheel and turn it and if it clatters like a B**** it's your CV joint.
Old 10-21-2010, 05:53 PM
pwr198's Avatar
how and where do you fill the swivals
Quick Reply: yet another issue
