$3.00 Headliner Fix
Old Feb 10, 2008 | 09:43 AM
DuplinDisco's Avatar
Default $3.00 Headliner Fix
Forgive me if this has been posted before but this is better alternative than thumbtacks until you can get it professionally repaired. My Disco doesn't have sunroofs but you may be able to modify it for your application.
Grab some self tapping or piercing screws (it will be cheaper to go to a hardware store and buy the screws individually.
Grab some screw covers to match your headliner
If you don't have sunroofs put them in the 4 corners of the indention
Be sure to hold the headliner tight when putting in the screws so it doesn't try to twist up on you. You may also want to make a starter hole before you drill.
Old Feb 10, 2008 | 10:09 AM
Chrisinhouston's Avatar
Default RE: $3.00 Headliner Fix
Great idea, it looks almost factory made! My Disco also did not have the sunroofs. Look at it this way, they will never leak on you now!
Old Feb 11, 2008 | 04:13 AM
mordor110's Avatar
Looks good, could be a semipermenent fix. 3M makes some spray on fabric adhesive. I was wondering if there's a way to get that in there through some pin holes or something and stick the fabric back in place.
lsmit605
May 11, 2011 11:50 AM
Disco Den
Mar 9, 2010 09:37 AM
2003Disco2
Jun 28, 2006 03:57 AM
LarDog44
Jun 26, 2006 11:39 PM
DiscoGirl
Jul 28, 2005 01:49 PM
