Headliner
Old Jun 7, 2005 | 08:47 PM
DiscoGirl's Avatar
8th Gear
Default Headliner
I own a 97 Disco and my headliner is sagging very bad. Does anyone know a company that you can order Land Rover Discovery headliners from? I have checked my local places and they said that the Disco is wider than usual headliners. Any help would be greatly appreciated.
Kassy
Old Jul 27, 2005 | 12:46 PM
kelemark's Avatar
Default RE: Headliner
I had the same saggy problem, especially where the sunroofs would go if I had them... I took the headliner out (not too difficult, just alot of un-screwing and plastic popping) and took it to a local upholstery shop for new cloth... Forget about the spray glue you can buy at AutoZone, it doesn't work. It cost me $175 for the new fabric, which comes with it's own glue and padding, they just lay it on the headliner (after cleaning all the old foam and glue off)... Re-installing the headliner was alittle more difficult by myself, but if you have a buddy to lend a hand it should be a snap... Just make sure that the shop you take it to leaves enough fabric on the front section to roll up and under the headliner. (mine was left alittle short so I had to use some super glue to make it look good)...
Hope this helps!!!
Old Jul 27, 2005 | 09:37 PM
duboff's Avatar
sounds like kelemark got it right. If you order the factory replacement you will not like the price. Some shops will do all the work and the repair for around. For the imediate time, stick pins will keep the thing out of your way until you can get it fixed. Also make sure the gaskets around the wind shield/ windows and sun roof don't leak. That is one of the causes of the failures
Old Jul 27, 2005 | 09:39 PM
duboff's Avatar
good shot on the super glue. Never thought of that one for the front tuck. thanks. duboff
Old Jul 28, 2005 | 01:49 PM
lt4you2's Avatar
I have the same problem and wife tried to fix by spraying glue. It worked for a bit but came down again. This time I'm going to attempt to so it myself
angasreid
Apr 20, 2019 10:38 AM
Old School
Jan 10, 2007 08:20 PM
2003Disco2
Jul 25, 2006 06:45 PM
2003Disco2
Jun 28, 2006 03:57 AM
LarDog44
Jun 26, 2006 11:39 PM
