$35 MAF! A good idea?
Old Jan 3, 2015 | 09:16 PM
cybercop's Avatar
Default $35 MAF! A good idea?
Land Rover Discovery Mass Air Flow Sensor Meter 2002 02 | eBay
http://www.carparts.com/details/Land...9-08598e4226c6
Should I be suspect or are these a good option?
Old Jan 3, 2015 | 10:02 PM
OverRover's Avatar
GREAT IDEA for the Sellers! Easy to temp you away from $35 when your other options are $100 plus. What brands are these things?
It's up to you...it's a $35 gamble. But I live by a simple rule: The cheapest is NOT the least expensive!
Old Jan 3, 2015 | 10:38 PM
cybercop's Avatar
I agree 100%, but wanted to ask.
BTW, what good $100 options do you know of. Cheapest I have seen for a OEM part is over $200
Old Jan 3, 2015 | 11:14 PM
OverRover's Avatar
Can't tell if it's "good", but listed as BOSCH Part # 0280217532 @ Rockauto for $101.99 RockAuto Parts Catalog
More Information for BOSCH 0280217532
At least it doesn't look like a bosch knock-off like the ebay finds.
Check the part number on your bosch sensor... ending 532?
Or > http://www.partsgeek.com/6gpxfx6-lan...sor.html?fp=pp
http://shop.advanceautoparts.com/p/b...7532&showTitle=
Use TRT30 for 30% OFF at Advance. Why am I still awake???????
Old Jan 4, 2015 | 08:24 AM
Alex_M's Avatar
I figured it wouldnt work but gave it a shot anyway. As I expected, it threw codes almost immediately. I shot the seller a message with what happened. They said Ok, sorry about that, heres your money back. Keep the sensor, if it doesnt work then we don't want it back. So that's that. Erik (Lucky 8) has 3 options; AllMakes for like $50 which he hasn't had good luck with, Bosch for around $150 which he seemed to like, and OEM for ~$200+.
Old Jan 4, 2015 | 09:36 AM
dusty1's Avatar
Why do I think Bosch is oem?
What is?
I've been running Bosch for about a year....no problems
Got it off here, $35 new
Old Jan 4, 2015 | 12:03 PM
cybercop's Avatar
What is?
Got it of where?
Old Jan 4, 2015 | 02:00 PM
dusty1's Avatar
I meant off this forum. from a member that bought it and didn't use it......he sold truck, I think.
Old Jan 4, 2015 | 05:07 PM
potxoli's Avatar
I had all sorts of problems with codes with cheap MAFs off of amazon and then got the bosch rockauto one for $110 and it worked great.
Old Jan 4, 2015 | 05:18 PM
ZGPhoto's Avatar
Bosch is OEM
