$600 Disco II
Old Jan 3, 2024 | 11:27 AM
Mikes Disco's Avatar
Default $600 Disco II
Hello,
Found a '01 Disco II on C/L in Seattle needs a XYZ sensor and a fuel pump need advice on whether to purchase or run local parts houses are not in stock how hard is the sensor to locate? and is the old one repairable?
Thanks, Mike.
Old Jan 3, 2024 | 01:28 PM
keninnc's Avatar
Some YouTube videos on both these repairs. After watching them I think you will have a good idea if you want to jump in and buy it.
Old Jan 3, 2024 | 04:00 PM
ahab's Avatar
First thing to look at is the frame, specifically between the rear axle and the rear bumper. Seattle helps, but none of these trucks are immune to prematurely rusting out back there.
Old Jan 4, 2024 | 01:49 PM
Harvlr's Avatar
I think it would have to be pretty bad to not be worth $600. Parts are readily available and not expensive, but you generally need to order them (from Canada I usually order from England).
Old Jan 4, 2024 | 04:54 PM
zski128's Avatar
You can get $600 bucks back for the cats alone assuming they are OE if the frame is gone. If you are loooking for a parts source almost can’t go wrong.
wildwilly69
Jan 28, 2024 02:11 PM
Moab63
Dec 10, 2022 09:27 AM
JHDisco2
May 15, 2009 04:20 PM
GoldDiscoII
Dec 1, 2006 09:51 AM
neilp
Jan 3, 2005 04:47 AM
