$9 bearing vs $45 pulley
While replacing the serp belt and tracking down a coolant leak, I decided to replace the idler pulleys. Cheapest I found was $45/ea for the 80mm. So I pulled the bearing out, measured it, and found them online for $9/ea plus shipping. Size is ID20mm x OD 52mm x 15mm Thickness
http://bearingsdirect.com/store/inde...t_detail&p=232
When I replaced the one on my '98, I got it pretty cheap. But the '04 has 2 diff sizes listed, 70mm for $25(from AB) or an 80mm for $45. Of course both mine are 80mm.
I was half tempted to try the 70mm and see if it would work, but I was worried about the centering being off.
I thought it must have been something like that, 'cause they said they had no listing for an '04 Disco.
But, I did end up getting the bearings at my local store($6 and change/ea) and poped 'em in.
The only prblem with just replacing the bearing is that now you have a great ebaring inside a pulley that is getting brittle. I have seen the pulley shatter on the back side and tear up the belt. For a couple $ more just get the universal pulley from Napa or O'Reilly's or whoever. Just take in teh pulley and they will match it with a universal one. Peice of mind in my opinion.
