$9 bearing vs $45 pulley
Old May 22, 2011 | 12:12 AM
kenk's Avatar
Default $9 bearing vs $45 pulley
While replacing the serp belt and tracking down a coolant leak, I decided to replace the idler pulleys. Cheapest I found was $45/ea for the 80mm. So I pulled the bearing out, measured it, and found them online for $9/ea plus shipping. Size is ID20mm x OD 52mm x 15mm Thickness
http://bearingsdirect.com/store/inde...t_detail&p=232
Old May 22, 2011 | 01:47 AM
mwindth's Avatar
Hey kenk...interesting, I'm rooting for the bearing!
Old May 22, 2011 | 08:49 AM
antichrist's Avatar
I think I paid about $12 at NAPA for mine about 5 years ago. They've really gone up.
Old May 22, 2011 | 08:50 AM
KenR's Avatar
Great info. I'm curious which closure type you used, rubber or metal. I've got some noises that sound like idler bearings going bad but haven't looked at 'em yet.
Old May 22, 2011 | 09:07 AM
kenk's Avatar
I haven't ordered them yet, as I'm hoping the one place in town that sells bearings will have them in stock(yea,right). But, if I order them, I will get the rubber seals. I honestly don't know the diff. But I have never seen/used metal sealed bearings. That was the first I saw them.
Old May 22, 2011 | 09:15 AM
kenk's Avatar
When I replaced the one on my '98, I got it pretty cheap. But the '04 has 2 diff sizes listed, 70mm for $25(from AB) or an 80mm for $45. Of course both mine are 80mm.
I was half tempted to try the 70mm and see if it would work, but I was worried about the centering being off.
Old May 23, 2011 | 08:14 PM
RoverMasterTech's Avatar
napa has replacement idlers for 12 bucks apice
I have the numbers at my shop, its like an astro van and a buick idler...
Old May 23, 2011 | 09:12 PM
kenk's Avatar
I thought it must have been something like that, 'cause they said they had no listing for an '04 Disco.
But, I did end up getting the bearings at my local store($6 and change/ea) and poped 'em in.
Old Apr 16, 2012 | 10:50 PM
outdoor7or24's Avatar
Default What are the model numbers?
"I have the numbers at my shop, its like an astro van and a buick idler..."
Do you have the numbers for these?
I am gona try to source these locally....
Old Apr 17, 2012 | 05:27 PM
handsome rob's Avatar
The only prblem with just replacing the bearing is that now you have a great ebaring inside a pulley that is getting brittle. I have seen the pulley shatter on the back side and tear up the belt. For a couple $ more just get the universal pulley from Napa or O'Reilly's or whoever. Just take in teh pulley and they will match it with a universal one. Peice of mind in my opinion.
