*old* misfires gone, *new* misfires present
Old Jun 21, 2018 | 09:21 PM
BowRat's Avatar
Default *old* misfires gone, *new* misfires present
About a month ago, I posted looking for some help/advice with a 5 and 8 cylinder misfire.
New Magnecores, new oem spec Champions, new front o2 sensors, cleaned MAF and that's it. Doing the above got rid of the o2 codes, cylinders 5 and 8 are no longer misfiring, but now 3 and 7 are misfiring.
03 D II, 98K with SAI
I should note that the truck ran free of codes or SES lights for about 15 minutes, then the SES light flashed 3-4 times, then stayed solid for the 1-2 mile drive home.
So, as it is, I've got p303 and p307 misfiring, OBD scanner indicates a level 2 severity of misfire (new reader, little documentation)
Checked plugs and both ends of wires (coil and plug ends) they "appear" to be fine, but that's just based on a visual inspection.
In preparing to tackle the original codes and troubles, I bought new coil packs, but did not replace them. I felt somewhat apprehensive about removing the upper IM, so I did not mess with the coil packs.
I don't own any other testing equipment other than the obd scanner, but can probably borrow or buy other test tools.
As always, any advice/help is appreciated.
Matt
JoeLena
Aug 4, 2017 01:50 PM
obababoy1
Nov 5, 2016 09:48 AM
kfx4001442
Jan 31, 2016 10:18 AM
abran
May 4, 2014 10:36 AM
Decoy76
May 12, 2010 09:07 AM
