'00 Disco II SLS issue
Old Aug 2, 2010 | 06:48 PM
catchthebig1's Avatar
Default '00 Disco II SLS issue
hey guys.....(a continually evolving question.....)
so, after doing enough searching/research, i am convinced that i need new air bag for the passenger side sls
questions:
1) is it necessary to replace both sides even if the driver side is functioning properly? (just in case....)
is this the part i am looking for: http://www.roverparts.com/Parts/RKB101200.cfm :: http://www.strutmasters.com/Range-Ro...-gen2-r-rr.htm
i have read some tutorials online on how to replace - and some make a differentiation between the part above, and just the "bladder" replacement - yet i cannot find any other part other than rkb 101200
if so, how easy is replacing this on my own and avoiding the $150/hr i am so prone to pay.....
seems like a simple matter of jacking the car, some retaining pins, air clamp, replace, done....can't be that easy though? can it?
Old Aug 2, 2010 | 11:30 PM
22Dirty's Avatar
I just got done dealing with this issue... I found that arnottindustries.com the manufacturer of air bags for many other makes as well as LR has the best deal on an airspring for the d2...
or you can use this direct link: http://www.arnottindustries.com/part...48_gid159.html
I replaced just the one... I'll replace the other when it goes bad....
Its fairly easy to replace your self.... only I worn you that you will have to lift the truck quite high due to the long travel of the suspension.... I used my forklift to speed up the lifting of it.... It should only take about a half an hour depending on your skills.... jack up the truck frame... take wheel off... have a jack under the axle as well... take pins out with screw driver or needle nose pliers... unscrew air... take off old collet... trim hose slightly... twist air spring and remove... replace w/new spring... use new collet... and reverse the process...
Its easiest if the spring is deflated prior to the r&r... if you need to deflate manually just disconnect the height sensor... the spring will deflate if the sensor is lowered... Good luck!!
Old Aug 2, 2010 | 11:48 PM
thanks dirty - sent you a pm also w/ a couple more quick questions
abran
Feb 8, 2015 06:50 AM
tunernewb92
Oct 20, 2009 07:15 PM
kkrover
Jun 19, 2006 12:13 PM
jmohr10
Jan 6, 2006 08:22 PM
