00 Disco II strange radio problem
Old Jun 15, 2009 | 06:04 PM
jasonpope's Avatar
5th Gear
Default 00 Disco II strange radio problem
My radio has worked great, no probs. until yesterday. I started the Disco and the only speakers that would work are the tweeters. It was working fine when I turned it off on Sat. All 4 tweeters work but none of the other speakers do. I searched the old threads and couldn't find the answer. Has anyone else had this problem?
Old Jun 18, 2009 | 08:52 AM
jasonpope's Avatar
5th Gear
Nobody?
Old Jun 18, 2009 | 09:29 AM
lipadj46's Avatar
I believe the amp is under the drivers seat. I have zero experience with the Disco sound system (besides reading through the Rave CD) but it sounds like you have a bad crossover circuit (circuit that splits highs and lows). Or maybe some wires or connections could be loose but I'm not sure how every speaker gets hooked up to the amp. Look through the Rave CD and try to track down the wires and see if anything is loose, remove and push back in any connectors. If there are any circuit breakers or fuses in the amp (don't think so) reset them.
If all else fails see if www.roverlandparts.com has a used amp.
ctsigler
May 6, 2015 02:56 PM
Extinct
Aug 8, 2014 07:39 AM
yonatan
Mar 10, 2014 11:14 AM
TTtheBear
Jun 6, 2012 07:55 AM
hazletbassist89
Feb 13, 2008 04:27 PM
