01 D2 electrical issues loss of Speedo and dash lights
Hi all this grows out of the the installation of a D1 Hi/Low shifter unit. Got the shifter in and the CDL is working. I had the CDL light coming on. I then discovered the Hi/low range shifter was not working Due to the Solenoid not working. I removed it and took the pin out. In the process I damaged the wire at the solenoid. So I just unplugged the connection. Great I now have Hi/Low range.
Not so great. No speedo, No Hi/Low indicator, No CDL indicator, I opened the tunnel back up and did not see anything obvious
