Dash won't work ...speedo,rev counter,oil and fuel gauge
Old Oct 14, 2013 | 02:25 PM
Strilciw's Avatar
Default Dash won't work ...speedo,rev counter,oil and fuel gauge
Hi just bought my first land rover discovery n reg and the speedo and such is not working any ideas and help would be appreciated. Chris
Old Oct 14, 2013 | 02:34 PM
abran's Avatar
Not sure if this is the problem, but check the small wire on the Alternator. I had some Tach and I think Speedo issues and it was a losse connection at the alternator.
Good luck, that is the extent of my knowledge there.
Old Oct 14, 2013 | 02:37 PM
robertmirwin's Avatar
agree with abran check for loose connections. also check fuses most important. I had a similar problem with mine and it was a dying battery. these trucks love there 12v and nothing less. i was only getting around 11.2v and nothing worked in mine. put in a new battery and everything worked as it should.
good luck
Old Oct 15, 2013 | 05:15 PM
Strilciw's Avatar
Thanks got it fixed was the fuse under the dash cheers again
vllageidiot
Nov 12, 2014 02:51 PM
mitsi88
Sep 24, 2009 08:37 AM
v8man1
Jan 22, 2008 10:49 PM
MilitantGrunt
Feb 27, 2006 10:10 PM
hollyw
Jan 28, 2005 09:47 PM
