01' DII fog lights inop
OK I have a 01' DII, It has the factory brush guard with the factory 7" round fog lights. I have what appears to be a OEM button on the cluster surround that has a pic of a foglight and a "2" in it. I turn that button on with the ;lights on and the button does not light up and nor do the fogs.
Am I using the correct switch? Is there something to look for that may be causing them to not turn on?? Any info would be GREATLY appreciated!!
The large fogs on the brush guard are only meant to work with the high beams on???
Well I went outside and turned the ignition to power, turned the headlights on and then turned the high beams on.. I pushed the fog"2" button and still nothing happens.
I did noticed that with the high beams on the lower fog lights will NOT turn on.
Is it possible its a blown fuse?? does anyone know WHICH fuse works the "2" fog lights?
Under the hood I see fuses for the standard fogs and those are good but I don't see a fuse for the "2" fogs
Have they ever worked for you? Are they original to the truck, or added after the fact? How are they wired? (i.e.- Using the factory wiring harness, or a separate harness, fuse, and relay setup?)
IIRC, the regular fog lights have to be enabled through a change in the BCU. Maybe these are similar?
sickrangerover
02-11-2007 11:44 AM
jaybe_2
08-02-2006 11:14 PM
