01 Disco 120k No Start
Old May 22, 2010 | 12:08 PM
umoms's Avatar
Default 01 Disco 120k No Start
Just bought a 01 disco and i been having problems the last few days with it.
One day it wouldn't start at all. It will turn over and it wasn't starting. I tried giving it a jump to no avail. I ran a obd reader and it gave me a code that said System Voltage too High. I checked the battery and alternator cables and they seemed fine. I deleted the code and still no start.
The next day it started up fine. I took it to Autozone to have the battery/alternator/starter tested and it was fine. I also took it to Advance auto parts for the same tests and they all passed. No check engine light on either.
The day after and ever since it won't start anymore. There is no check engine codes. I am getting to spark at all and no fuel coming in either. I checked all the fuses as well.
I think it maybe security related. I have 2 keys and neither work. Or possibly a fuel pump or crankshaft sensor?
What are your thoughts? Or how can i test these things or diagnose some more?
Old May 22, 2010 | 11:53 PM
handsome rob's Avatar
CHances are it is the crank shaft positioning sensor. They are relativiely inexpensive but a little pain to replace. They will work intermittently so that is why sometimes it works then sometimes it will not. I would start there and then drive it til it needs it again.
Old May 23, 2010 | 01:19 AM
jbriggs's Avatar
Check it out. I had the same problem.
File Type: pdf
Old May 23, 2010 | 09:04 AM
They are right, if the crank sensor has failed, it will not send a signal to the ECU for the pump to activate as well as the coils to fire.
That high voltage code was most likely caused by jumping the truck.
In the future, always give us the 4 digit fault code numbers not what you think they stand for.
MARSRover
Jun 22, 2012 01:47 PM
moody
Jun 5, 2011 10:34 AM
BajaBound
Jan 29, 2009 10:14 AM
arsenalgunners
Jun 25, 2008 09:15 PM
tsuami1
Feb 5, 2008 09:04 PM
