01 Disco differentials
Old Jun 21, 2010 | 08:16 PM
toad2's Avatar
Default 01 Disco differentials
are they dana 44's. if not what are they? thanks in advance
Old Jun 21, 2010 | 08:17 PM
No.
They are Rover axles and diff's.
Old Jun 22, 2010 | 08:03 AM
Just curious, why do you ask?
Old Jun 22, 2010 | 09:01 PM
toad2's Avatar
My front diff has a slight leak and i was thinking dana 44 seals would be quite common. I haven't looked but maybe i can get a seal at atlantic british ?
Once again, let me thank you guys for all the info. This is a great resource for a rookie like me.
Old Jun 22, 2010 | 09:09 PM
Where is the diff leaking from?
A clogged axle breather can over pressurize the diff(s) and then force the gear lube out of the weakest point.
So check your axle breather first, take it off and blow through it, also remove it from the axle if you can and make sure that is also clear.
Old Jun 22, 2010 | 09:35 PM
lordmorpheus's Avatar
...and if the front axle breather is retained in the axle the same way as the rear axle on the DII, stay tuned for my how-to on breather removal this weekend.
Old Jun 23, 2010 | 07:29 AM
toad2's Avatar
ok, i'll be waiting for your tutorial because i have no idea where the axle breather is or how it is retained. Thanks
ps, it is seeping out where the driveshaft connects to the housing.
Old Jun 23, 2010 | 07:37 AM
Atlantic British is one of many sites that will carry all the seals.
Old Jun 23, 2010 | 07:43 AM
toad2's Avatar
thanks mike and spike and also morpheus
Old Jun 23, 2010 | 01:12 PM
Danny Lee 97 Disco's Avatar
I have got check out these axle breathers you mention. I was totally unaware of their existence. Guess I'll read the RAVE and go exploring underneath the beast again.
