02 D2 coilspring help pls
Old Mar 8, 2013 | 02:26 AM
cavdiver2's Avatar
Default 02 D2 coilspring help pls
I'm sry to ask what I'm sure has been asked all the time, but I didn't see anything with the tires I want to go with. I want to do a 2" lift using 235/85/16 from treadwright. What springs, shocks do you suggest? Should I go to springs in the back and get rid of the stock air system. I have a roof rack now and plan on adding a front brush w/winch and all skid plates as well as sliders. Thanks again for any help as always!
Michael
Old Mar 8, 2013 | 06:15 AM
coors's Avatar
Either RTE, OME, or Terrafirma 2" HD kits. Do a some research to determine who's kit will. Best suit your needs.
I would ditch the bags and go to coils. Remember, you're gonna need to swap out the rear air spring seats to cool spring seats. Plus, you're going to have to disable the air system. AB sells a kit I do believe. I'm not to familiar with the specifics someone else may chime in.
Old Mar 8, 2013 | 06:22 AM
Michael, do you like your SLS and want to keep it like I did for nearly 10 years, then we should talk, switching to a new coil set will give you a completely different ride.
If you want some help with this, send me your number and I'll call you.
If you don't the SLS, go to a medium duty OME lift and steering stabilizer and you will have a good quality lift and the clearance you want.
provocateur
May 30, 2008 07:17 PM
xstreetz
Sep 16, 2007 06:22 PM
argoman
Defender
Apr 28, 2007 12:32 PM
Disco Kiwi
Jan 31, 2006 07:13 PM
