02 Sensor problems
I recently replaced sensor 1 bank 1, and then found out the wiring on sensor 1 bank 2 was bad... so I attempted to rewire them. It is now throwing codes P0134, P0145, P0154, and P0155. I know they are all either non detection or 02 heater sensor codes, I’m just not sure how to fix it. After replacing Bank 1 sensor 1 it ran fine and I had just the code for bank 2 sensor 1. I just came seem to narrow down anything that would specifically causing these problems.
How did you attempt to rewire. Sounds like the problem is with your rewiring
