02 sensor / running open loop
Old Aug 23, 2012 | 03:25 PM
bballjames's Avatar
So it goes closed at 140. It will run fine for about 15-20 minutes. Then it will randomly go open loop again at normal operating temps. I just had the SES light come on with the following codes
P0150
P0174
P1174
any ideas where to start?
Old Aug 23, 2012 | 04:33 PM
bballjames's Avatar
I searched the codes and found a lot of people with similar posts, but I can't seem to find a solution anywhere. If I hadn't washed the engine, I would probably be inclined to replace the O2s, but I didn't have any problems until I did that...
Old Aug 23, 2012 | 05:31 PM
With your mileage and 1 dead front 02, I would replace both the fronts then clear the codes, that should fix it.
Old Aug 24, 2012 | 09:08 AM
bballjames's Avatar
Thanks mike. I read a couple of other posts where they replaced both sensors and then the codes came right back after a month or so... Is there any thing else I can check before I replace them?
primussucks
Oct 9, 2013 09:00 PM
cipher982
Jan 17, 2013 01:20 PM
Eaglerover22
Jul 6, 2012 10:03 PM
jaydog101
Nov 28, 2011 05:35 PM
Discolife
Nov 25, 2011 11:36 AM
