03 Clock module replacement
Old Jun 12, 2023 | 09:51 AM
Flamgat's Avatar
4wd High
Default 03 Clock module replacement
First post, just got my vehicle. Among my checklist of things to do, my clock is not functioning correctly. Looks like some of the LEDs (?) may have burned out. I see the module includes the central door luck button. Do I remove the whole module and replace it? If so, how do I remove the module? Thanks!
Old Jun 12, 2023 | 10:34 AM
Harvlr's Avatar
I was trying to find it, but there was a recent post about a slick aftermarket clock that fits in the same location, and I think it included a couple of USB ports. Maybe someone who knows will chime in here.
Old Jun 13, 2023 | 10:43 AM
ahab's Avatar
As far as removing the existing module, slide an old hotel room key or license or CC or similar in on each side to release the spring-loaded clips and the whole thing should slide out. Then you can separate the clock to replace bulbs or whatever.
Old Jun 14, 2023 | 01:22 PM
YETIX's Avatar
It helps to cut about 1/8" to 1/4" off one end of each card.
Old Jun 14, 2023 | 01:45 PM
L33DiscoII's Avatar
I found the aftermarket clock (link). Kind of a neat solution. The reviews say the clock is in 24hr time format only. My personal experience with 3D printing things is that they can become a bit fragile over time with wear and heat.
Last edited by L33DiscoII; Jun 14, 2023 at 01:46 PM. Reason: made link more apparent
Old Jun 16, 2023 | 11:51 AM
Sandman614's Avatar
They use cheap ebay parts in a 3d printed housing. Check the pics for part numbers and the 3d print thread for a file.
Old Jun 19, 2023 | 10:13 AM
Flamgat's Avatar
4wd High
Thanks guys, gonna try the card removal first and try to source a donor module from ebay
sam4927
Feb 1, 2024 11:43 PM
DakotaTravler
Mar 26, 2021 10:11 PM
ljdiscovery
LR4
Jul 21, 2019 02:29 AM
tedjan
Aug 1, 2014 12:04 PM
Cirrus
Jan 21, 2007 01:36 AM
