In-line t-stat mod bottom hose
Old Jun 7, 2023 | 12:13 AM
Tony Luna's Avatar
Default In-line t-stat mod bottom hose
What is everyone using for the bottom hose? I tried the Gates 22073 but wasn’t too happy with the fit.
Old Jun 7, 2023 | 12:38 AM
Dervish's Avatar
Put it the other way around?
I just did the Extinct inline with that hose, and it's all good.
Almost thought I fudged it up as did not fit, but I turned it the other way round.
Don't have any photos of it (odd, I usually take lots of photos) and not near that D2 now..
Old Jun 7, 2023 | 01:41 PM
Tony Luna's Avatar
No cutting?
Old Jun 7, 2023 | 07:57 PM
zski128's Avatar
Somewhere in this forum there is a part number for the lower hose that’s a perfect fit with the inline kit that removes the need for the splice. I think it was a Gates part number from RockAuto
Old Jun 7, 2023 | 09:05 PM
Externet's Avatar
The radiator outlet to the pump inlet in two pieces, a 'T' in the middle gives me a drain and the connection for the heater core and the reservoir hoses.
Old Jun 7, 2023 | 09:37 PM
Dervish's Avatar
Originally Posted by Tony Luna
No cutting?
Can't remember that I would have cut it at all..
Old Jun 8, 2023 | 09:31 AM
gecko951's Avatar
The perfect fit lower hose is Gates 22073 and here is the explanation:
https://landroverforums.com/forum/di...30/#post829489
I just used my original hose and the inline thermostat provided splice but I did replace my brittle plastic four-way connector with the aluminum one from carrs4x4.com
https://carrs4x4.com/collections/dis...be-by-carrs4x4
Old Jun 8, 2023 | 10:43 AM
Dervish's Avatar
Took a pic of the gates hose installed...
Old Jun 19, 2023 | 03:00 PM
Discorama's Avatar
Here is my solution for the lower hose: Gates 22073 (thanks for the tip) and a sensor adapter (34mm, $10 Amazon). I cut it into two pieces and made them shorter. The sensor adapter makes it possible to rotate one of the hose pieces to make it align perfectly. This solution even allows to go under the coolant reservoir hose quite straight between the radiator and the coolant manifold.
Davis31052
Nov 2, 2020 07:27 AM
cappedup
Apr 26, 2016 09:31 AM
dr. mordo
Oct 6, 2012 01:12 AM
rlcj_racing
Mar 27, 2012 12:19 PM
