'03 DII Fuel issue...?
Old Jun 25, 2008 | 12:46 AM
JohnnyQuick's Avatar
4th Gear
Default '03 DII Fuel issue...?
Okay... First, I just bought my first Rover last December, and this is my first issue, so I'm an admitted newbie to the LRs. I was a BMW guy until I decided I wanted to climb big mountains... ;-)
The issue: It started to have issues restarting after running. Abruptly, it would start and run when cold, and then not after stopping. Waiting 10-15 minutes would allow it to start again. Then in the course of a day, it went to more than a half hour before it would start. So I parked it, and started researching.
I have now removed nearly all the interior in the back, and lifted the carpet to expose the fuel pump access. I confirmed that when the key is turned, there's no action with the pump. So... my questions before I drop hundreds on a pump.......
It has about 70K miles, and a somewhat dubious maintenance history. Can anyone give odds on the pump being the problem? I know there are about a dozen sensors that effect the fuel delivery, and I'm replacing the pump relay and filter as a matter of good practice, but is it appropriate for the pump to crap out at this age? Is there anything else I should test before dropping $409 at the dealership for the OEM pump? (Should I bother with the OEM, or is the aftermarket one okay? It's $317, but it's worth a C-Note to not have to tear out the interior again anytime soon...) Oh! AND... when I bought it, I was getting close to 14.5 mpg, and it dropped to about 11.5... any connection? Oxy sensor? Thoughts?
Thanks y'all!!!
Old Jun 25, 2008 | 08:09 AM
Default RE: '03 DII Fuel issue...?
It is not the pump, it is most likely the crank sensor that shuts the fuel off as it is starting to fail. I would also replace the fuel pump relay, cheap and they do fail.
PM me with your tele number if you have questions and want to talk.
Old Jun 25, 2008 | 11:31 AM
4th Gear
So I found that on the '99s the crank sensor is located on the bell housing (accessible from underneath, I presume) on the driver's side. Is that still true on the '03? Do I need special tools to reach it?
Old Jun 25, 2008 | 12:05 PM
It is bolted to the back of the engine block, below the head on the drivers side.
Old Jun 25, 2008 | 12:39 PM
petestd5's Avatar
Default td5 auto gearbox fault
Okay, well totally new to this so bear with me please. Just bought a 2001 TD5 auto with 70k on it. Full landy history. Gearbox serviced at 49k. Had a bump in front but nothing serious. Left standing for 2 months and now car drives to 3100rpm before it changes gear into third and then limp home mode! Plugged into landy diagnostics comes up with "stall speed monitoring"? when driven with diagnostic plugged in there is no speed out put from the gearbox? It also does not register the gear your in. The dash shows the gear your in so if you move the stick up and down it will go up and down on the dash. Sounds like a speed censor to me but i dont no one fron another? where are they situated? Does the switchgear play up? Due to it being stood could it be as simple as the battery?? starts the car first turn of the key? No engine codes and no engine lights light up. Just the M & S light flash when limp home mode activated? any help??
Old Jun 25, 2008 | 01:42 PM
Default RE: td5 auto gearbox fault
ORIGINAL: petestd5
Please start a new post, your issue has nothing to do with our gas engines crank sensor.
Thanks
Old Jun 25, 2008 | 01:52 PM
4th Gear
Tons-O-Fun! Anything special I need to remove to access it? Some funky $100 tool?
Old Jun 25, 2008 | 02:30 PM
A couple of wrenches.
Travelor
Sep 24, 2015 06:11 PM
Kingmarine
Feb 26, 2012 09:27 PM
JumPeR04
Apr 7, 2011 09:52 PM
tunernewb92
Oct 20, 2009 07:15 PM
dms98e
May 9, 2008 08:36 AM
