03 disco 2 air not blowing hard
Old Feb 18, 2013 | 01:18 PM
AU_LRDiscoII's Avatar
Default 03 disco 2 air not blowing hard
About a week ago my fan stopped blowing completly. I have no idea what to do. It blows cold or hot air whichever is turned on but its the same air flow whether it is one low or high. i just had to change the water pump yesterday (not sure if the problems are related) and nothing changed. I also checked the fuse box and everything is in order. Not sure where to look next or if this is a common problem. Again the heating and cooling works just not blowing it in the cabin. thanks in advance for your imput.
Old Feb 18, 2013 | 01:37 PM
jafir's Avatar
Does the sound change when you pick a different speed? If so, then you might just have trash in the blower box. If it stays the same, maybe you've got a bad resistor Resistor - Climate Control Blower Motor (Genuine Part # JGN100011) or Resistor - Climate Control Blower Motor (Genuine Part # JGN100010) depeding on VIN.
Old Feb 18, 2013 | 03:01 PM
has no sound what so ever. like i have no blower at all
Old Feb 18, 2013 | 03:05 PM
jafir's Avatar
Look under the glove box. You should see a hole in the cardboard trim. The blower motor sticks through the hole. Give it a good firm tap and see if it kicks on.
Summer681
Dec 5, 2023 07:21 AM
missalison
Jun 5, 2012 07:29 PM
Joseph David
Mar 14, 2011 04:04 AM
slexum
Jul 23, 2009 02:43 PM
hkp
Sep 13, 2006 11:46 AM
