Oil Seal Removal
Old Feb 18, 2013 | 03:24 PM
robdis96's Avatar
Question Oil Seal Removal
Working doing the front cover gasket kit change and after removing the crankshaft pulley RAVE says to use LR tool xxxxxx to remove oil seal. Is there an easier way to do it? Tried a couple things and couldn't get it to move. Read a lot on the forum on install tips but not much getting it out.
Thx
Old Feb 18, 2013 | 03:35 PM
br0keit's Avatar
Most people use a flat head to get it out but be careful not to gouge up your timing cover. I actually had better luck with a flat nail remover, Put the "V" part around the seal and use the side on the timing cover (CAREFULYL!) for leverage.
Old Feb 18, 2013 | 06:44 PM
drowssap's Avatar
a couple of sheetmetal screws into the seal and a pair of pliers will also work
austinlandroverbill
Aug 23, 2015 01:03 PM
kilkenny
May 15, 2015 06:07 PM
outdoor7or24
May 21, 2012 08:34 AM
yloDiscoII
Feb 10, 2010 10:03 PM
shagybruce
Feb 8, 2007 02:52 PM
