03 disco 2 no crank no spark
Old 12-09-2021 | 02:13 PM
Gracewyattdad's Avatar
Default 03 disco 2 no crank no spark
2003 disco 2. New fuel pump, new ckp. No fuel, no spark. Help
Old 12-09-2021 | 02:17 PM
Harvlr's Avatar
Has the inertia switch been tripped?
Old 12-09-2021 | 02:18 PM
I pressed it down multiple times
Old 12-09-2021 | 02:59 PM
Richard Gallant's Avatar
Does it turn over ?
Old 12-09-2021 | 03:01 PM
Turns over strong. Battery between 10-11 v while turning over
Old 12-09-2021 | 03:57 PM
Check the relays for fuel, no spark is harder but when you turn over does any rpm show.
Old 12-09-2021 | 04:06 PM
No rpm on gauge. Not sure if my OBD reader shows rpms
Old 12-09-2021 | 04:41 PM
If the RPM does not move that is almost always the CPS, you should get a small movement while the engine turns over.
Old 12-09-2021 | 04:51 PM
Camshaft position sensor correct?
Old 12-09-2021 | 05:06 PM
Harvlr's Avatar
Crankshaft position sensor
Quick Reply: 03 disco 2 no crank no spark
