03 disco 2 no crank no spark
Old Dec 9, 2021 | 05:27 PM
Gracewyattdad's Avatar
Ckp reset after replacement? Anyone know the steps?
Old Dec 9, 2021 | 10:29 PM
Richard Gallant's Avatar
There is no reset it just works, are the spacers in the right place ?
Old Dec 10, 2021 | 12:30 AM
The Deputy's Avatar
Did it just not start one morning or did you buy it this way or did it die while driving...some history of "why" you replaced pump and crank sensor would be helpful.
Old Dec 10, 2021 | 09:09 AM
Replaced fuel pump because I was unsure of maintenance history. Drove fine for 2 days after I bought it. Died while idling. Cranked back up. Wouldn't crank back up after I went to store. Got towed. Cranked after it came off tow truck. Replaced ckp cause of YouTube. Current condition- no fuel pump during ignition, and no spark. Fuel pump components are good.
Old Dec 10, 2021 | 10:16 AM
checked non ground wires from ckp while engine turning over. Both had slight voltage. Ckp good?
Old Dec 10, 2021 | 04:04 PM
Extinct's Avatar
Jumper the fuel pump relay fuse and see if you have pressure at the test port shrader valve. Oreilly has a pressure test kit you can rent. If you have 50 psi, you can forget fuel pump. If not, that is your problem. If you have fuel pressure, put the old CPS sensor back on and see what you have.
Old Dec 10, 2021 | 04:57 PM
Fuel pump is not turning on with key in position 2
Old Dec 10, 2021 | 05:26 PM
The Deputy's Avatar
l'd say if the crank sensor is creating a pulse/signal voltage...it's good. Now, whether that signal is making it's way to the ECM or not...is another issue. You may have broken wires, poor plug connection, etc.
Since you haven't verify fuel pressure, while cranking engine over, we really are just guessing. Until you do that, you could check drivers compartment fuse box, there is a fuse for the coil packs (fuse 14...l believe...but l'm not sure...it will be marked on cover), plus, there is an ignition relay, R4, lower lefthand corner of fuse box, swap it out with similar relay and see if you have spark. Had one Dll where the relay fell out in my hand when l touched it, pushed back in...and rover started right up.
Also, check all of your fuses...the ECM is fused.
Old Dec 12, 2021 | 10:46 AM
Update
All fuses and relays have power with key in position 2. Getting signal from CKP to ECU at ECU plug. No fuel or spark while cranking
Old Dec 12, 2021 | 12:59 PM
Fuel pump doesn't start in key position 2
