03 Disco Front winch mount
Old Jun 17, 2008 | 08:40 AM
rugbier's Avatar
Default 03 Disco Front winch mount
Hey Guys,
I have almost exhausted all channels before I've decided to bug you.
Here is my dilema. I want to mount a winch on my 03 disco, BUT, I want to keep the factory bumper and the Poly A-Frame Brushguard. I figue maybe the mesh grill will have to go, but if I look through thatarea, I cab see the frame right after the aluminum end pieces.
I know for the D1 a front 2" receiver mount was offered, but I've always wondered what would happen at a 90 degree pull well even at a 45 pul, I mean, by far I am not Einstein, but receivers were ment to pull straight not angled , right?
So in other words, I checked with the local welder, NO HELP, and I am hoping some of you have done this set and can point me in the direction to obtain one.
Your help it is always appreciated
Thanks in advance
Old Jun 17, 2008 | 10:01 AM
meltdowndave's Avatar
Default RE: 03 Disco Front winch mount
Although I can't help you out with the geometry, I'm in a similar position. The difference being that I already have the winch and am trying to find a factory A-bar or brushguard that will work with my winch install.
Anyway, I have my winch mounted on a DAP tray that's installed behind the stock front bumper. This is called a discrete mount. The tray is about $130.
A regular poster did this set up and created a "How to". Try this link and see if it helps you out.
http://www.discovery2.co.uk/winch.html
Funtogun
Jan 5, 2015 05:45 PM
acg
Nov 3, 2013 10:58 AM
khuds308
May 13, 2013 09:48 PM
Scotauto
Mar 6, 2013 12:45 PM
rugbier
Jun 17, 2008 09:49 AM
