'03 Disco More Lift! 2" done
Old Nov 7, 2016 | 05:58 PM
03discoken's Avatar
Default '03 Disco More Lift! 2" done
Hello everyone,
I recently purchased and installed the full Terrafirma 2" lift spring conversion and I'd like to add additional lift to my Discovery II.
I've since completed the install and it looks great! If you want to see photos, come check out my Instagram: 03DiscoKen
I'm looking to add a 1" spring spacer on the front shocks and 1.5" spring spacers on the rears.
Having said that, I have some questions and also looking for some advice.
1. Will I need to remove the cross bar under the front drive shaft after I install the 1" spacers in the front?
2. Will I need to purchase a new front drive shaft to accommodate the additional height? Total of 3" lift after spacers are installed. As of now, with the 2" lift, it's operating just fine with no issues.
3. I know I'll have to purchase the longer brake lines. But is there an extension that can be purchased for the wheel speed sensors?
4. I know placing a spring spacer on the front springs will not affect the shock travel, but how will a rear 1.5" spacer affect the rear Terrafirma shocks considering it will be a total of 3.5" rear lift?
Suggestions? Advice?
Thank you all in advance.
Old Nov 8, 2016 | 09:32 PM
BBSam's Avatar
Discoken, sharp looking!! I've have an 02disco, and I'm doing my homework on shock/spring combos right now. I have a question- how much did the 2" lift really raise the car? Compared to original height? Did you install the medium duty?
Thanks for any suggestions, tips.
Sam
Old Nov 9, 2016 | 12:22 AM
Frank4's Avatar
Should have gone with the RTE 3" coils!
Old Nov 9, 2016 | 03:29 AM
The Deputy's Avatar
What is stagram?
Sure would be nice to see some pictures.
Brian.
Old Nov 9, 2016 | 06:27 AM
JUKE179r's Avatar
From what I've read and researched, raised up 2 inches (like I have) you can keep stock parts. Going 3 inches and up you'll have to extended the brake lines, wheel speed sensors cable and change the radius arms.
I'm sure there are other parts that need to be changed due to the increased height.
Old Nov 9, 2016 | 08:01 AM
Joe!'s Avatar
With my 2" I extended the brake lines and abs lines. I ran it with just extended brake lines and kept pulling out the plug on the rear abs lines
Old Nov 9, 2016 | 08:41 PM
JUKE179r's Avatar
I also have the 2" extended brake lines from Atlantic British just for the hell of it but have the stock wheel speed sensors on all hubs. No problems.... Touch wood.
Old Nov 10, 2016 | 12:24 PM
Frank4's Avatar
No need to change anything with 3". Been running it for years with ZERO issues. I would however look into those mods if I was going over 3".
Old Nov 11, 2016 | 05:25 PM
Ole Miss Disco's Avatar
7th Gear
That looks fantastic! Great pictures, following you on Instagram now.
1. Did I see you did new brakes too? Where'd you order those from?
2. Looks like you put the 265/60R18 tires on prior to the lift. Was there any rubbing at all? Or does that size pretty much require the lift?
Old Nov 12, 2016 | 09:00 AM
Charlie_V's Avatar
I have the TF +3 springs and added pucks for 2 inches more, so slightly more lift than you. As Frank said, no abs extensions are needed, but brake lines are. Your driveshaft will be fine though if it is old, it may fail quicker.
Really the only issue is that your steering may get more difficult with little return to center, as the caster angle increases. Also, after you do the additional lift, check your steering linkage to be sure it is still linked.
jycsalas
May 23, 2019 03:02 PM
DiscoDubs
Apr 23, 2014 12:13 PM
glassman66
Jul 17, 2012 08:31 AM
GamecockRover
Jul 16, 2012 02:00 PM
kfx4001442
May 18, 2008 09:50 PM
