03 DISCO OIL PUMP DATE
Old May 22, 2008 | 08:38 PM
trioinfo's Avatar
Default RE: 03 DISCO OIL PUMP DATE
disco mike & meltdowndave
i know, replacing a failing oil pump is just a bandaid to the prob, but since I dont want to make a fast unresearched decision. Is there an estimated time or miles i met get before i have to worry about it again? Only reason I ask, is for my families peace of mind... we bought our disco to go on road trips & now I would be nervous thinking about any little noise or such 400 miles from home.
Old May 22, 2008 | 09:05 PM
meltdowndave's Avatar
Board consensus is in the 40-50k range.
But there's no hard or fast rule as to when, exactly, it will fail.
Old May 23, 2008 | 10:14 PM
trioinfo's Avatar
Thanx for all the info, I will go & get the oil pressure checked at the shop & see how much it would be to replace the pump... for now. Any idea on how much that should cost?? & Also what shoild the proper oil pressure be on my 03 disco with 80Kmiles
Thanx Again
ORIGINAL: meltdowndave
Old May 24, 2008 | 08:34 AM
tee51397's Avatar
Oil Pressure:
At Idle: 0.7 bar (10psi)
At 2K RPM hot: 3.4 bar (50psi)
Oh, also meant to say that you should just invest in a gauge (they're cheap) and check it yourself. It'll be a good thing to have as you should keep an eye on the pressure just to make sure. Regular pressure checks will also allow you to establish a baseline.
Chris-bob
Off Topic
110
Sep 7, 2013 03:08 AM
Snafu / Disco Fries
May 4, 2012 03:37 PM
Spencerfitch
Apr 2, 2011 02:06 PM
russoaks
Jan 10, 2009 08:03 PM
05LandRover
Off Topic
23
Jan 20, 2006 08:26 PM
