03 discovery driveline question
Received 1,189 Likes
on
I believe the 03 is longer than the 02, if both are original shafts. 03 has a different trans. If the 02 is an aftermarket shaft, all joints greaseable, then it will probably fit both. Most aftermarket manufacturers just make one longer shaft (splined area compensates) that fits both years.
Brian.
Brian.
