03 Discovery... flashing m&s lights
Old 09-04-2011, 12:26 PM
tarpon66's Avatar
Default 03 Discovery... flashing m&s lights
Just had my transmission fluid , filter,gasket changed.. now my M & S lights are flashing.. only seem to go on when I start the truck and engage the tranny in reverse , little bit of a" klunk " when first put into gear.. Mind you there were now problems before the transmission service, just doing some preventative maintenance before the 3000 mile trek across country..
I have checked the charging system and battery, all is well, so they have been ruled out.. I wouldn't think it was the xy switch because like I said no problems before the transmission service was done..
Any help would be appreciated
Respectfully,Mike
Old 09-04-2011, 03:02 PM
Adigorn's Avatar
well as they come on staight away seems to be electric problem
broken wire not reconnected connector etc
you should hook it up and read faults
difficult to quess
Old 09-05-2011, 11:31 AM
tarpon66's Avatar
Seems as though the M & S lights and the D light on the dash don't start flashing until I go from P to D.. If I then shift to N shut the engine of restart and shift to 1st or 2nd then to D lights go of and stay off, until I start from P to D again... drained the transmission today after doing the initial service 2 days ago and same thing... I think the code came back as low signal to the Xyz switch... again no problems until after the transmission service was done 2 days ago ...
Thanks for the response
Mike
Old 09-05-2011, 12:04 PM
buick215's Avatar
Post the exact code that you are getting.
Old 09-06-2011, 04:16 PM
BigBoss0311's Avatar
Have you had your drive shaft rebuilt?
Old 09-06-2011, 06:06 PM
buick215's Avatar
What does the driveshaft have to do with the flashing M&S lights.
Old 09-07-2011, 05:42 AM
Fairview's Avatar
Mike
Mike,
My 03 exhibited similar problems. When shifting from P to R, then backing up, when I moved into D, the flashing would start. I could restart in N, then drive off and the flashing would stop, transmission would shift through the D gears normally. It really seems like moving through the reverse position caused a short or something, like there was a bad connection.
Replacing the xyz switch took care of the problem. XYZ switch in a Land Rover box brand new was $249.
My theory on these xyz switches is that the air conditioner drain on the left side dumps water right on it. How smart is that design? Still love my Discovery though.
Good luck. Jeff
Old 09-07-2011, 07:22 AM
tarpon66's Avatar
Jeff, thanks for the response.. Could you please tell me where you picked up the XYZ switch???
Best regards,Mike
Old 09-07-2011, 09:52 AM
tarpon66's Avatar
Default Aftermarket XYZ switch
Thanks again Jeff,
Found an after-market XYZ Switch at rockauto.com
RockAuto Parts Catalog
$237
Cheers Guys
Old 09-07-2011, 10:47 AM
Best regards,Mike
I know you have mentioned that your battery is good, don't care, go to a local parts store, have them do their free charging system test and see what that shows, should be between 13.6 and 14.4 volts other wise that can make your lights flash.
Quick Reply: 03 Discovery... flashing m&s lights
