03 discovery ps leak
Old Feb 15, 2011 | 05:25 PM
tstuit's Avatar
3rd Gear
Default 03 discovery ps leak
I have a 2003 discovery and I finally located my ps leak. It is coming from the base of the solid line at the front top of steering box. I loosened the nut that holds the plate in place and the line appears to be seating properly but after tightening it is still leaking. the plate that holds the two lines to the top of the box appears to bowed downward in the middle. Can anyone tell me if there is supposed to be an o ring on this line to keep from leaking around the flared base?
Thanks
Old Feb 15, 2011 | 07:07 PM
I have no idea if there is a o-ring there or not.
I do not think there is.
Power steering leaks are very common.
Start buy using a power steering fluid with stop leak to top off your system.
If it does not get better after adding half the bottle or so then you need to dig deeper.
Old Feb 15, 2011 | 08:14 PM
tstuit's Avatar
3rd Gear
Default I tried
I already tried stop leak before I found out where it was leaking from. Tomorrow I will try to put on an o ring and re tighten. It went through one quart today alone. It doesn't leak from the line but where the line goes into the top of the steering box/
Old Feb 15, 2011 | 08:59 PM
Gotcha...either a o-ring or maybe thread tape?
Old Feb 15, 2011 | 09:16 PM
roverDII's Avatar
The plate that holds down both hard lines is supposed to be Flat. Remove it and hammer it back to as flat as you can. Also, check the threads on the fastener that holds it down and if they look worn replace it as well.
Yes, those lines do have O-rings, you should replace them.
Old Feb 16, 2011 | 06:43 AM
Bundu's Avatar
Banned
There is an o ring, replace it.
Old Feb 16, 2011 | 03:21 PM
tstuit's Avatar
3rd Gear
I need to get the plate off of the tube so I can hammer it flat. Can anyone tell me how to get it off. I can not see where the end of the line that goes to the radiator ends at. I am assuming that it must be disconnected at this end to slide the plate off of the line.
Thanks. Any help would be greatly appreciated.
ZMonet
Jun 24, 2016 04:00 PM
tito5590805
Sep 27, 2010 11:32 AM
nolabrooke
May 21, 2010 09:33 AM
lipadj46
Jul 8, 2009 07:41 PM
rgrizzard
Mar 6, 2008 10:16 AM
