03 Discovery S and Tow Indication Light
I was wondering about the tow indication light in the instrument dash. How is that light illuminated/ activated. I installed a curt hitch and uHaul imported vehicle 4 pin trailer wiring kit. Will I factory or similar trailer wiring harness work this hidden function if there is?
Yes, this lamp is activated by the trailer to warn that there is a trailer hooked up and the electrical circuits are working properly or not. This lamp is activated either by the factory fitted electrical loom or a correctly installed aftermarket wiring loom. I am not sure whether all D2's have this trailer lamp as standard or a selected few models.
I believe the trailer light indicates that the system does a self check of the trailer electrics and is there to indicate all is OK and there is a trailer hitched up. You'll note the trailer light flashes when the indicators are used. I believe you also need an HD indicator relay/module fitted when using a trailer. If you have a tow bar fitted it may well have been installed. My trailer electrics and tow bar were all installed when new when I bought the D2 new from the LR main dealer so I cannot be sure about this.
Additionally, the trailer indicator will only advise of a connected trailer if the trailer is using incandescent bulbs for it's lighting. If the trailer uses LED indicators, then there's a good chance that the indicator will not illuminate, even if all of the connections are working properly.
Elley
Sep 18, 2015 03:09 PM
