'03 Fog light install tech question
Old Mar 14, 2008 | 10:12 AM
yeager6's Avatar
Default '03 Fog light install tech question
Hello. I am adding in bumper OEM fog lights to my S model 2003. Since they are pre-wired I was wondering if anyone knew which collor switch connecter leads to the fogs from the passenger cabin. I have a choice of green (my vote) or black. You're probably thinking I'm in over my head ... and your right : ) I had no idea how difficult this would be. The wiring and bumber install are easy but I was told by the dealership to make sure I had the exact parts and I still may need to visit the dealership to tell the computer the lights are there. Apparently on the 03 and later models this is more of a mouse click than a switch. Just a warning to anyone considering this modification... do your homework. Thanks for the help, any tips are greatly appreciated. Cheers !
Old Mar 14, 2008 | 12:01 PM
Urban Panzer's Avatar
Default RE: '03 Fog light install tech question
Hi
The fogs are controlled by the BCU, thats why the factory switch is only "momentary". The BCU does all the switching. It also needs to be configured as to which way the fogs will work, either with dipped headlights or side lights etc, this is why testbook / rovacom is needed.
I "think" its the green connector, but im not 100%, Ill have alook at mine and post an update, mine is only a 2001 model, so it may be different altogther
Old Mar 14, 2008 | 01:21 PM
tee51397's Avatar
I'm not sure if this is what you are asking exactly but it is the top left blank on the binnacle. when I pull my fog switch out the connector is green.
Old Mar 14, 2008 | 01:46 PM
yeager6's Avatar
Thanks for the quick replies. The green is in the right place... thanks for the advice!!!
abran
Oct 1, 2013 09:09 PM
psykokid
Dec 9, 2011 10:45 PM
mlshelton
May 16, 2008 08:14 PM
kevinBrady
Jul 23, 2007 08:12 AM
Charles11816
Feb 14, 2005 12:39 PM
