03 Plenum/manifold vacuum line clip red
Old Jul 5, 2011 | 12:28 PM
footie11's Avatar
Default 03 Plenum/manifold vacuum line clip red
What's the part# for the little red clip on the passenger side of the intake that locks in the one vacuum line? I'll have a pic tonight!
Won't be able to get to dealer this week so any source online?
Thanks
Old Jul 5, 2011 | 08:39 PM
I dont know but this part breaks all the time, so buy several.
Old Jul 5, 2011 | 09:47 PM
jafir's Avatar
I'm not sure about a clip, but I think you might be talking about this fitting:
Intake Manifold Fitting PCV Hose To Valve Cover | Land Rover Engine Parts at RoverParts.com 03-04
Intake Manifold Fitting PCV Hose To Valve Cover | Land Rover Engine Parts at RoverParts.com 1999-02
Old Jul 5, 2011 | 09:51 PM
bosshogt's Avatar
From what I have heard you can find this fitting in brass at a hardware store, like Ace or True Value screw/bolt isle. Also check the air fittings section with a ****** end and other end threaded. Then it will never break again. And its probably $3.00 instead of $14
Old Jul 6, 2011 | 07:46 AM
Just call your dealer and order a replacement for the red disconnect.
They rarely brake, unless some one tries to remove the line and doesn't know how to do it.
Old Jul 6, 2011 | 09:15 AM
mln01's Avatar
My ever so helpful dealer told me a year and a half ago that the red collar into which the brake servo vac line is seated is available ONLY as part of a replacement plenum. If anyone has a part number for the collar only I would love to see it posted here.
And yes, I was removing the vac line without knowing how to do it (push in on the red fitting while pulling out on the vac line). Counterintuitive. Oh well.
In the meantime I cut one side off of a nylon grommet from Radio Shack and fit the vac pipe through it and into the plenum. It has worked well for 20 months now. Remember that the vacuum is pulling the line toward the plenum, not pushing it out. My grommet fix seals the line just fine, but I would replace it with the proper red collar if I could get my hands on one.
Old Jul 6, 2011 | 09:17 AM
Contact PT Shram he will have a loose one laying around, I bet.
izi6969
Freelander
Oct 23, 2012 10:16 AM
blingenfelter
Freelander
Aug 22, 2010 07:19 AM
m5ccie
Sep 16, 2008 08:49 PM
