03 Tick Solved
Old Oct 3, 2011 | 10:24 PM
turbodave's Avatar
Glad you got the oil pressure thing worked out.
Your ticking must not have been the 'loose liner syndrome' - which is really loud (sounds like a big 1.5 cylinder diesel engine is deep inside the engine).
I suspect you just had a low oil pressure at idle speed, which coupled with the typical main-bearing clearances you'd be seeing with 140K miles meant your tappets weren't being pumped up sufficiently. It probably wasn't all 16 - instead you'd have one, or a few that drain down and needed pressure to keep them pumped up.
I doubt it was your other two suggestions about the pump slap or the timing chain.
Old Oct 4, 2011 | 09:26 AM
DeepBlueWater's Avatar
Thanks Dave for the input! Learning more with every Disco mechanical misfortune. This car is a far cry from my original 1969 VW van or Nissan 4cyl 4x4. Now if I could get through my 340 code, I could move onto some fun stuff- like new suspension...
xengineguy
Nov 12, 2015 12:23 PM
XCELLER8
Sep 19, 2009 03:27 PM
zracin
Mar 7, 2008 01:17 PM
Kraftyz51
Aug 19, 2007 03:58 PM
97XD
Feb 2, 2007 07:46 PM
