'04 DII brake and rotor job
Old 09-28-2012, 08:49 PM
Racer X's Avatar
This is a great write up!
On the locating screw... with the calipers installed, how could the rotor possibly fall off during a wheel change? Just curious, as many other cars I've worked on don't have that screw, and rotors falling off aren't much of an issue.
Old 09-29-2012, 11:04 AM
Great write up, and if I could add a couple of ideas also.
When you first remove the rotor, take some emry cloth and sand the rust from the hub and apply a very thin film to prevent them from rusting which will make taking them off in the future a lot easier.
Always grease the studs before torquing them to 102 foot pounds.
Always do a full 2 quart DOT 4 brake flush and use a good synthetic for a firm pedal.
Might also replace the rubber brake lines if over 100,000 mile for safty reasons as well as a firmer brake pedal.
Old 09-29-2012, 12:38 PM
Bkreutz's Avatar
The screws hold the rotors on the hub while its moving down the assembly line before the calipers are installed. They do make it easier when doing brake work (as opposed to spinning a lug nut on to keep the rotor in place while installing the caliper)
Old 09-29-2012, 06:48 PM
blamo's Avatar
Rotor can't fall off with caliper on Just sayin.
Old 09-29-2012, 10:56 PM
Antmen's Avatar
Man, good call on the calipers not allowing it to fall off... I guess I was seeing these things for so long without the calipers on them. Doh!
Thanks, Mike, for the tips! I plan on going stainless lines in the Spring.
Old 07-03-2013, 05:09 PM
lmalbright's Avatar
Great write up. I am attempting to do the same on my 2004 Discovery. I am not having any luck finding a #4 Phillips head bit anywhere. Sears does not have one in its current impact driver kit. AutoZone and Advance Auto don't carry them and even NAPA is a no go. Any ideas? Thanks.
Old 07-03-2013, 06:48 PM
G Reeves's Avatar
old screwdriver, punch, small cold chiesel any of these and then a hammer.
Old 07-04-2013, 09:25 AM
lmalbright's Avatar
Thanks. I'll give it a try.
Old 07-04-2013, 05:01 PM
lmalbright's Avatar
Update. Tried the impact wrench with a #3 after soaking it with rust penetrant. Gave it a few taps and they came loose on both sides. Front brakes and rotors done. Rear will have to wait till Saturday. Also have to replace the hub on the driver's side.
Fenix
08-24-2015 03:22 PM
jroy
04-21-2012 06:42 PM
mcrw
08-16-2010 09:00 PM
mishon
07-20-2009 07:13 AM
hooman
12-16-2007 10:19 PM
Quick Reply: '04 DII brake and rotor job
