04 Disco Front Door Locks will not lock/unlock have ?????
Old Sep 30, 2023 | 07:48 PM
Johnyakimo1855's Avatar
Default 04 Disco Front Door Locks will not lock/unlock have ?????
Ok, after reading a TON of threads I did not find an answer to my question.
04 Disco Front Door locks not locking or unlocking. I replaced the interior fuse box like was told to me and still no luck. I hav e 2 sets of actuators from Will Tillery (one for this rig and my wifes G4) and neither is locking/unlocking when I plug them into the harness and hit the button. I CAN hear them clicking like they want to open and close but I hear the ones installed doing the same. My questions are the following:
1) Are the actuators grounded through the harness? or are they grounded by the mounting bolts to the door drame?
2) What is the wiring diagram pin out for the drivers master plug?
3) What should the volt & amps be for the pin out?
4) ANY Help is appreciated.
This and the horns are the last items on this 2 year process and it is off to my father in laws (gift)
Thanks guys
Old Oct 1, 2023 | 07:05 PM
Extinct's Avatar
Sounds like you have bad actuators. The brushes in the motors wear out. You can replace the motors but it is involved, or you can get new or used actuators that are working. If Will sent you actuators that do now work I am sure he will replace them. You can test the actuators out of the truck by applying voltage on the correct pins, have a look at the rave for the pinout.
emille26
Jul 5, 2019 11:22 AM
RAJOD
Dec 20, 2017 11:14 AM
coors
Jan 5, 2015 10:23 PM
nick_m3
Dec 18, 2014 06:57 AM
drpenaranda
Nov 10, 2005 10:15 PM
