04 Disco II Dash in a 2000?
Old Feb 3, 2011 | 06:18 PM
mcwilly21's Avatar
Default 04 Disco II Dash in a 2000?
Looking at replacing the dash (upper portion) in my 2000 Disco II, and was wondering if all years from 01-04 would fit? Not sure of any electrical/wiring differences between the years. Appreciate any guidance. Thanks.
Old Feb 3, 2011 | 06:27 PM
brianb883's Avatar
With my 04, it seems like majority of electrical parts have different part numbers for the 03-04 years. The interior fuse box was different, so are the switches for the heated seats. Those are the only electrical parts I've changed myself. I'm not sure if the dash is similar, but to be on the safe side I'd recommend staying with a dash from a 99-02. Check AB or any rover parts site, and you will find one part number for 99-02, and another number for the 03-04s...usually more expensive.
Old Feb 5, 2011 | 08:13 AM
tee51397's Avatar
Aside from color, the dashes are exactly the same. Several of the wiring schemes were changed but that would be irrelevant for your purposes, all switch sizes and functions are the same. The difference in part numbers is due to the fact that the '03-'04 switches and such are black instead of ash grey. If you pop off the faceplate of the switches the bodies are totally interchangeable.
duke051184
Jan 14, 2013 02:23 PM
Disco2Fever
48
Mar 12, 2012 12:39 PM
cellman01
May 15, 2009 10:31 PM
Airwolf1
Nov 6, 2006 04:27 PM
duoglide98
Mar 7, 2005 08:26 PM
