04 Disco II...Help me target the Oil Leak!
Old Jul 26, 2013 | 07:33 AM
dougwrench55's Avatar
Default Better way
I agree with the others that u need to clean off the engine. Then add engine oil dye, drive it a bit and check for the source with a blacklite or dyelite. this way is more accurate in diagnosing your leak.
Old Jul 26, 2013 | 09:18 AM
Yoops Racing's Avatar
Originally Posted by drowssap
this is on the new cannibal motor? are you sure it is the pan and not the front or rear seal?
put a thin coat of black RTV on both side of the gasket, there is no need for them to leak.
I will do this today as well. It looks to be from the pan. Only started after a 2.5 drive to the mountains. I will try to tighten the bolts slightly
Old Jul 26, 2013 | 09:59 AM
Madlands's Avatar
The plug next to the oil filter that doesn't seat itself all the way can leak pretty good. Mine is on my 04 and it is running down the pan. Next time I change the oil I'm gonna take it out and wrap some Teflon tape on there, should fix it. You might wanna give it a look and make sure it's not from there and running down the side of your pan.
Old Jul 26, 2013 | 10:02 AM
Agreed...this may be the culprit. Heading to NAPA for Black RTV
Old Jul 26, 2013 | 10:29 AM
Dan7's Avatar
Dye is the key. The fan and gravity will distort the location even if you clean it off. Dye don't lie!
Old Jul 26, 2013 | 09:37 PM
jruproductions's Avatar
6th Gear
Ended up being timing cover gasket on the passenger side. Going to replace the water pump while my mechanic is down there as well..good idea?
Old Jul 27, 2013 | 06:40 AM
The timing cover job allows several other fun things: A kit of about $115 includes the $7 gasket, a new front seal, water pump gasket, and a set of oil pump gears. Worth doing the oil pump.
When replacing the pump consider an upgrade one that has a bronze impeller, like from BP Utah.
Replace fan clutch. Clutch and water pump have been dancing for millions of spins around the dance floor, and know each other, warts and all. hey have worn old together and are a perfect fit. Toss a new one in the mix and the old part will wear more rapidly.
While oil pan is off, clean pickup, replace pickup tube gasket, and two dabs of loctite on the bolt threads of the pickup.
Old Jul 27, 2013 | 09:20 AM
caymandrew's Avatar
Careful with this, I ordered this gasket as per Buzz's advice: GASKET OIL STRAINER-BLOCK V-8 3.5/3.9/4., RNM062, ERR3788 - Rovers North - Classic Land Rover Parts
Turns out my 2001 Discovery 2 does not have a gasket on the oil pick up!! It's an o-ring!
You can see the second graphic of the newer oil pan assembly in the lower right of this:
Discovery II Engine Lower End - Rovers North - Classic Land Rover Parts
Why rovers north doesn't appear to sell this o-ring I don't know. Bought it from O-Ring Oil Pickup - 4.0/4.6 Engine (Genuine Part # ERR4794) - Land Rover gaskets and seals from Atlantic British
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
Display
Dec 12, 2007 09:36 AM
mcb123
Nov 28, 2006 03:38 AM
