04 Disco II Trouble Codes driving me nuts
Old May 15, 2026 | 05:18 PM
Johnyakimo1855's Avatar
Default 04 Disco II Trouble Codes driving me nuts
ok, i have a G4 that i have been working on off and on for a year. Got it all sorted and let me father in law drive it. No codes nothing. He gives it back with the starter acting up and O2 sensor codes. Nothing else.
I replaced the starter and all 4 o2 sensors. Started up and drove it for 200 miles and ran GREAT, As im pulling in my driveway from driving back and refilling the tank. It started running rough and check engine light comes on. I cleared it and drove again and same codes. P0134, P1000, P0300, P0301, P0302, P0305, P0307. WTH. All new plug wires and plugs before I gave it to my father and law. Has new battery. Have never had this many codes on this rig. its always been 02 related. Any help is appreciated. i am tired of having to revisit this Disco about this.
THanks Everyone
Old May 15, 2026 | 05:48 PM
Extinct's Avatar
My guess is you still have the coils in the factory location, because troubleshooting a misfire after you move them is cake. No idea what 134 and 1000 are, I don't memorize them, but I kind of doubt they are serious. You might want to post the reason codes.
Old May 16, 2026 | 04:00 PM
longtallsally's Avatar
I’m gonna go zero to apocalypse: did he let it get hot? How are your temps? Might want to do an exhaust gas test, and hopefully I’m very wrong.
Old May 17, 2026 | 02:18 PM
JohnZo's Avatar
Four cylinders are misfiring. Could be coil problem. Could also be related to re-filling the tank just prior to the problem? Start with fixing the misfires, like Extinct mentions often, misfires are usually ignition related.
Old May 19, 2026 | 11:10 AM
WaltNYC's Avatar
OK.
P0134 = no activity from upstream O2 sensor, bank 1
P0300 = multiple misfire
P0301 = misfire cyl 1
P0302 = misfire cyl 2
P0305 = misfire cyl 5
P0307 = misfire cyl7
P1000 = not clearly defined (not in RAVE).
First thing is to check the wiring on the bank 1 upstream O2 sensor all the way back to the ECU
Old May 19, 2026 | 06:44 PM
Extinct's Avatar
No activity 02 does not cause misfires. If you disconnect it then it will revert to maf-rpm fueling
devr13sdiscovery1
Dec 15, 2019 05:36 PM
TDisco2
Feb 15, 2019 09:38 AM
Elcham
Aug 28, 2015 08:32 AM
IndianJoe
Dec 4, 2012 05:13 PM
lipadj46
Jun 12, 2009 12:04 PM
