04 Discovery II goes into limp mode when shifting into neutral
Old Dec 28, 2022 | 04:43 PM
betzdII's Avatar
Originally Posted by XRAD
Did you replace the XYZ switch with new or used? You can remove the center console and check the diff locking solenoid for the the 'click...at least then you can tell if that is the noise source and work from there....
might be a faulty xyz....
used. And I did remove the rivets from the console and it is clicking at the solenoid. I can’t attach the video, it’s to large
Old Dec 29, 2022 | 04:14 PM
XRAD's Avatar
yeah...might be the XYZ.....You could just remove the solenoid......if everything else works fine...
but probably the best fix is a new OEM XYZ....there are several contact switches in the XYZ which are a bit touchy....
Old Dec 30, 2022 | 12:59 PM
betzdII's Avatar
I picked up another xyz switch from a good running 2002 (tan colored switch) and its doing the exact same thing as the black colored xyz switch. I'm not sure spending 800-900 new switch will solve my problem.
Old Jan 2, 2023 | 04:36 PM
betzdII's Avatar
Well after pulling my hair out (or whats left of it) The Discovery II would go into limp as soon as I switch the shifter from Reverse to Neutral. I can hear a clicking from the fuse panel under the steering wheel. It would click faster faster once shifted it into N with the engine running. Without the engine running I could here it click real slow not as fast as when the engine is running. The click is coming from the (TYCO V23081-xxxxx) relay. Is there a way to replace the relay or do I have to replace the whole fuse panel? I'm hoping this is my problem. Any help would be appreciated...or Is this normal to click?
Thanks Bub
Old Jan 2, 2023 | 08:49 PM
mollusc's Avatar
Those boxes are usually replaced only as a whole unit. There's a big mess of circuitry on them. The onboard relays really aren't replaceable separately.
Old Jan 2, 2023 | 11:07 PM
betzdII's Avatar
I guess I'll be sourcing a another fuse box than.
Thanks for responding.
Bub
Old Jan 3, 2023 | 08:23 AM
mollusc's Avatar
Might be worth taking a close look around the area to make sure there's no evidence of water leaks or something else that might have caused the failure.
Old Jan 3, 2023 | 12:02 PM
betzdII's Avatar
Yeah good point. I'll do that. Is there a way to see if the transmission thats in the car now is original to the car?
Thanks, Bub
khuds308
Feb 26, 2018 03:22 PM
Woodyk
Aug 31, 2017 02:00 PM
dis2creek
Oct 9, 2016 12:25 PM
halbertse
Aug 8, 2015 07:42 PM
floundering
Apr 8, 2014 07:38 PM
