'04 hse7 Discovery heavy right rear leaning
Woke up to an extreme right rear leaning '04 disco. Picture attached. It's as if I have a dead flat tire, but tires are inflated proper.
I'm kinda panicking. Is this just a shock or coil problem? If so, expensive to fix? Or something one can do on their own?
Pre-Thanks for any advice. I need it, brothers.
Sorry for the upside down pic. Can't get it right side up on the iPad.
https://www.arnottindustries.com/par...48_gid159.html
You need a rear air bag. Its an easy diy job. I'd recommend replacing both if you could.
Hey Dusty - is that true? I enjoy your sarcasm on this forum, but just want to clarify it *is* that easy...?
Also, can anybody explain the difference between the standard air spring and this one, for a couple hundred $$$ more. AIR SPRING REAR DISCOVERY II w/LEVELING, RND823, RKB101200 - Rovers North - Classic Land Rover Parts
Air spring w/ leveling
Thanks
Thanks
