04 Steering Gear Top Plate Leak
Old Apr 16, 2018 | 10:37 PM
04SE5's Avatar
3rd Gear
Default 04 Steering Gear Top Plate Leak
Hey Guys,
I've been reading older posts about PS Fluid leaks from the steering gear, most of which point towards replacing the gear.
I made mine squeaky clean and traced a pinpoint leak to one corner of the top plate on the steering gear, (the one with 4 bolts holding it down). It's an extremely slow, minor leak. Seems like the scenario a PS Fluid with stop leak would be perfect for. I know a lot of guys say no to the stop leak, as well as using anything but the Land Rover fluid (eats the seals etc.), though I don't buy that second part. Have seen one run 10 years plus with Valvoline PS and no issues.
In any case I haven't taken a LR steering gear apart yet, and I haven't seen a seal or gasket available that looks like that top rectangular plate, but I gotta think opening it up, cleaning it, and using an appropriate gasket maker would solve the issue. Seems wasteful to chuck a silent, perfectly operating gearbox away for replacement due to teeny drip from it's casing.
What did you do? What do you think?
ALSO: Just installed new PS pump and all new hoses, no leaks anywhere else, just the corner of the steering gear.
Old Apr 16, 2018 | 11:41 PM
Jeff Blake's Avatar
kit QFW100180 includes a seal/gasket for the cover plate. I'd start with that. Also check the torque on the 4 bolts
Old Apr 17, 2018 | 09:39 AM
04SE5's Avatar
3rd Gear
Thanks for the tips...is that top plate seal a circlar shape? I guess I was assuming a rectangular gasket as I didn't see it in the kits. Also, found an online source citing 66 fp on the torque, anyone know for certain? Thanks.
dforrestca
May 19, 2012 09:09 AM
whoman101
Apr 23, 2012 09:20 PM
Rover Kid
Member Group And Special Buys
Dec 4, 2008 06:52 PM
cosmickites
Defender
Oct 14, 2008 08:40 AM
