'04 T-Case Purchase...
Finally got out to pick the case up tonight, had trouble coordinating schedules. Needless to say, I am S-T-O-K-E-D;
So now, my question is, what should I do prior to installing?
1. Solenoid (Mine failed on my stock case, can I just remove this with no ill effects?)---(And what is the point of the thing, if you can just remove it?)
2. Neutral Saftey Switch (I hear bad things about this, what can I do to prevent this biting me in the behind?)
3. Fluid (I'm going to a flush/fill and probably reseal the inspection plate, as it looks like there was little bit of leakage)
It's cool to see the T-case out of the truck to actually "see" everything.
What's the CDL interlock? Thanks for the tip on the bearings, seems like a good $60 to spend for a little extra peace of mind.
As far as resealing goes make sure you replace the stuff you can't get to after yourtbox is installed. The tbox input seal, transmission output seal, and the tbox.intermediate shaft seals (o rings) To do the o rings just remove the intermediate shaft locking nut, prop the tbox on its side on an output flange and some blocks so the shaft is vertical, tap the shaft outabout 1 inch replace the oring on the shaft at the front, replace the oring in the tbox on the back (nut side) slide shaft back in and tighten locking nut and stake it (there is no crush collar for bearing preload on this intermediate shaft just shims). the reason you tilt the tbox on an output flange is so that the intermediate gearset does not drop or move. it's a heavy piece of metal, and is easier to keep in place than get back into place.
I put a 2004 transfer case w/linkage in my 2001 Disco II a few months ago (paid $400.00). Keep track of the bolts that bolt the transfer case to the adapter plate. The bolts are of various lengths and you need to get them back in the correct spots.
Luckily I've got a couple buddies with some experience that SHOULD be coming over to help/watch/laugh at me while I attempt this
YLo,
If you going to go to the trouble of resealing all the covers, seals and bearings there is a full kit you should consider from AB
Transfer Box Gasket & Seal Kit LT230 (RTC3890 Same Fit As Genuine Part # RTC3890) - Land Rover kits from Atlantic British
Bearings F&R Output
Bearing - Ball Type - Multi-Use (STC1130 Same Fit As Genuine Part # STC1130) - Land Rover clutch associated from Atlantic British
Heat Sink Oil Sump...Way cool (works on micro processors why not on your TC case
Write-up from our buddy in the UK.
www.discovery2.co.uk - Transfer box Sump
For only $97 to your door the billet oil sump heat sink can be yours from Lucky 8
Lucky8 Llc. - Take the road less traveled...
Might as well throw on the trick heat sink & added gear oil capacity. Might have to mod your exhaust a little to get it to fit, but maybe not. I resealed most all the covers on a 2002 case that I swaped out for the front output. I used gray Permatex RTV and it seemed fine for the guy who purchased it from me.
Bearings F&R Output
Thanks man. I got some advice from a couple Rover nuts (one is a tech), that advised me to leave the bearings well enough alone. I'm going to clean up the exterior, oil up all the linkages, new fluid, put new output shaft seals, mainshaft seal, and rear transmission seal and call it good.
That cooler is pretty sweet, tempting, but don't think I can justify it, wish I could though
Did you have any trouble removing the crossmember or the Y-pipe? Any tricks? Heat?
